Fast rails
Fast rails
Hi , i have fast 90 with 90 t/b installed in my car , i have Fast rails without any installation kit so what i need to buy to install the rails ?
thanks
thanks
i would get our FAST fuel rail install kit.
RGR501F.
that'll get you set up right.
i dont have fast rails. If your running stock return line..you need to run a hose over to the return line. So you need more braided hose, the -6 quick disconnect fitting. a #6 to 3/8 with 1/8npt fitting gauge adapter to mount your fuel psi gauge inline. And another 90 degree connector.
Check out ls1speed.com and their fuel section.
So the only thing I would need is an install kit? I found the kit and it comes with a crossover line, the main fuel line, and and adapter for the hard line. This is for fast fuel rail set-up on a fast 90.
