ls6 intake install (grinding)
Old 02-08-2009, 01:36 PM
Curveball TECH
TRANSdAMn 2k's Avatar
Default ls6 intake install (grinding)
I'm about to throw an ls6 intake on my 00 t/a. I'm going to stay with my coolant lines and grind the bottom down. I was wondering what you guys used to do this? Sandpaper?
Old 02-08-2009, 01:45 PM
GO BABY GO's Avatar
I used a dremel. Worked out pretty well.
Old 02-08-2009, 03:47 PM
HavATampa's Avatar
It's just small plastic fins. Dremel, drill with sandpaper rolls, pocket knife, whatever it takes.
https://ls1tech.com/forums/showthrea...ferrerid=13535
Old 02-08-2009, 10:49 PM
TTA1437's Avatar
+1 the link from HavATampa
I used an air die grinder with a carbide bit.
I was careful with the cuts but it took no time.
Old 02-08-2009, 11:08 PM
Curveball TECH
We went ahead and dremeled it then put it back on. BUT, I have a vacuum leak somewhere, argghhhh. You can hear it at idle but goes away when it I give it any gas.
I'm going to check the hoses tomorrow. Also, I don't think my map sensor made a great seal to the new intake. The only other possibility is that I didn't cut the ribs all the way down flat. Do you have to get those dead even with the flat surface underneath? I can't wait to rip it all off again
Old 02-09-2009, 12:08 AM
5.slow99's Avatar
i would just buy a small dremel kit so you can get all the sizes, fits you need, worked fine for me.
Old 02-09-2009, 03:33 AM
frankmarroquin's Avatar
Me to I used a Dremel... Pretty easy just becareful with the Shaving they are hot and shot all over the place...
Old 02-09-2009, 11:17 AM
BigKap94z's Avatar
Small chisel and light hammer taps did the trick for me. Did it on a couple intakes without any issues.
