speedometer question
I dont know about the speedo itself, but if you were using the factory speedo you would need to adjust the trans settings as the gearing is different. When I get home if no one has posted a better fix I'll post the numbers I have
Well biggest thing is I guess I don't know how the 700 operates the speedo? It doesn't go through the PCM... So does it have an electical output on it or something? As far as the guage it has one input that come from either the PCM or a sending unit...
Well it is actually a 4l60 and came out of a suburban... Put it up in the air today and it has a sensor... Looks like a 2 prong sensor right by the output shaft? Is that correct?
