ls2 with 5.3L patriot heads?
Old 02-08-2009, 05:44 PM
5.7LRX7's Avatar
Default ls2 with 5.3L patriot heads?
is this possible and is it any benefit over the stock ls2 heads on a mostly stock ls2 motor? i know its an improvement on the ls1's given the reason but on a ls2 is it any different?
Old 02-08-2009, 07:20 PM
slowandrichws6's Avatar
yea you will get alot of compression
Old 05-28-2009, 12:14 PM
5.7LRX7's Avatar
as for flow rating tho and overall power, would they be better than the stock ls2 heads? and as for compression would it still be able to run on 93 octane?
Old 05-28-2009, 10:53 PM
Bring the Noise's Avatar
If I'm not mistaken the stock LS2 heads flow around 260 cfm at .600" of lift.
Patriot Ported 5.3 heads flow 296 cfm at .600" lift per there flow chart.
https://www.patriot-performance.com/...ome.php?cat=36 (list of all 5.3 heads from Patriot).
Going by there web site, they offer them in 67cc and 63cc assembled and 63cc bare (part # 2007 for the 67cc and # 2027 for the 63cc). What I'm unsure about is if those chamber sizes are for 4.00" bore or for the 3.78" bore of the 5.3L?
Quick Reply: ls2 with 5.3L patriot heads?
