SDCE tensioner Blew up
Well I was coming home from a gun show that was about 70 miles away. I all of a sudden noticed i couldnt hear my SC anymore. I pulled over and found that the belt had slipped off. When i got home i put the belt back on and found it to be walking tawards the back of the car. So i started pulling the SC bracket off. this is what i found.
A crack, I prolly just over tightend the thing. I was trying to pull off the pulley thinking that i could just weld it, then this happend. With only a little force.
I guess i found out why my belt was walking around. I think that every time hit the gas the bolt would move a little then flex the tensioner. I cant belive how easy that tensioner snapped.
Anyways does anyone have any clue how much a new tensioner would be?
and has this happend to any one b4?
TT-TECH Veteran
Well they wanted to charge me $150 for a new one and wanted me to send my whole bracket back to them so I went and found the tentioner my self and make them myself if I mess it up but it has been holding for about a year now with out any problems so if you want to do it your self here is the autozone part number it was about $48 bucks 305201. GL!
This is why I designed my own tensioned bracket, I was worried this type of problem would occur. The way the SDCE is setup puts a large amount of strain on the tensioner housing with the pulley spaced out so far from the arm to clear the bracket. There is a reason tensioners keep the pulley right off the arm, so that the arm doesn't experience the twising/side load like that.
If you do a search on my name you'll find the post I made about my bracket.
I never broke mine or had any issues with it, I sold it to KP still in excellent condition too. I wonder if he ever broke it?
But there you go, 50 bucks and a PN and a short trip to Autozone and you are all set.
