Right way to burp or bleed 98 ls1 cooling system
Old 02-08-2009, 06:49 PM
stock302mustang's Avatar
Default Right way to burp or bleed 98 ls1 cooling system
please help.Trying to figure out best way to do this...
Old 02-08-2009, 07:06 PM
nemss1's Avatar
ive always let the car run with the radiator cap off and put the cap back on after no more bubbles came up
Old 02-08-2009, 07:12 PM
New water pump,new thermostat housing and thermastat,new belt.. still getting hot.. i loosened the bolts that hold steam tubes to heads and nothing is coming out...????
Old 02-08-2009, 07:22 PM
bluehawk2's Avatar
Yeah you either have something blocking the coolant passages or most likely you have a pocket of air in your system.
I usually fill mine with the front of the car jacked up. crank it up with the radiator cap off and watch the temp gauge closely . It isn't going to flow until the T-stat opens. it may take a couple of times doing that. Just cut the car off when it starts getting hot and let it cool and try again
Old 02-08-2009, 07:25 PM
7camaro7's Avatar
I think your thermostat might be sticking... I flushed my system a lil while ago and I just filled the radiator till it was full, fired it up and let it run and added accordingly... Its been full ever since.
Old 02-08-2009, 07:27 PM
its brand new. how do i test it.. i heard boil water and drop it in?
Old 02-08-2009, 07:34 PM
nemss1's Avatar
possibilities: stat sticking, need to bleed system, a blockage
u can test the thermostat in a pot with boiling water
Old 02-08-2009, 07:41 PM
goint to rule out blockage i flushed rad all day,all hoses etc..
Old 02-08-2009, 08:12 PM
nemss1's Avatar
try testing the thermostat and bleeding the system
Old 02-08-2009, 08:14 PM
Whats the right way to do it?
Old 02-08-2009, 09:04 PM
crossroads's Avatar
i just disconnected the line at the throttle body till I got fluid then made my connection....think i read that on ls1howto.com somewhere?
but it worked for me just fine
Old 02-09-2009, 03:35 AM
frankmarroquin's Avatar
I had the same problem but I just left the car running and finally the Stat open on its own.... I saw the temp drop drastically
Quick Reply: Right way to burp or bleed 98 ls1 cooling system
