STS turbo lag video...
Here is a video that shows how a STS system spools. Make sure to read the description of the video as it has some good info.
http://www.youtube.com/watch?v=rdjh3EY6shU
says nothing about the size of the turbo, plus from the description the guy is still running a stock motor, which meens he has higher compression (generally spools better with higher compression), and hes only running 6lbs of boost based on his boost gauge.
I'm still not convinced its anywhere near as good as a front mount setup
