Help with 99-02 cluster in 98 car please!
Also posted in converions & hybrids.
Alright guys here's the rundown...
1998 Trans Am, formerly A4
Now: 2000 LS1/T56
2000 harness and PCM
2000 fuel tank and sending unit
Everything is wired in and working with the exception of the 99-02 instrument cluster. That is my only concern, and my only thing left to do. What specifically do I need to do to make this cluster work?
What I do know is that I do NOT need to swap to a 99+ dash harness, and that 98 uses 35 wires for the instrument cluster where as 99+ only uses 17 due to data being recieved through a serial data wire. This is the most in depth info I have been able to find after a couple hours worth of searching. Not very in depth
I suppose pinouts for the 98 and 99+ instrument clusters would help a lot. I was able to find a pinout for the 99+ but not the 98. There is one thread for 98 cluster pinout that shows up in the search but it is a dead link! I cannot for the life of me find a pinout for the 98 cluster
Can anyone here help me out? This is all I need to do and the car is DONE!
Thanks!
-Dan
Now: 2000 LS1/T56
Thanks!
-Dan
98 cluster
A1
PNK
39
Power feed from gages Fuse 9
A2
DK BLU
1936
Fuel gage signal
A3
GRY
728
SECURITY indicator lamp control
A4
BRN/WHT
419
SERVICE ENGINE SOON indicator lamp control
A5
PNK
39
A6
YEL/BLK
68
Low coolant level indicator control
A7
BRN
358
AIR BAG indicator control
A8
PPL/WHT
1572
TCS OFF indicator control (with NW9)
A10
TAN/WHT
33
BRAKE warning indicator lamp control
A11
LT GRN
11
High beam headlights on
A12
PPL/WHT
237
FASTEN SEATBELT indicator lamp control
A13
ORN
640
Power feed from PWR ACCY Fuse 7
A14
RED
225
Generator output indicator control
A15
BRN/WHT
1173
Oil level lamp signal
A16
DK BLU
1537
LOW TRAC indicator lamp control
A17
DK GRN
135
Coolant temperature sensor signal
B1
BRN
9
Odometer illumination
B2
GRY
8
IP illumination lamps feed
B3
BLK
650
Ground
B4
WHT
375
SKIP SHIFT indicator lamp control (V8 only)
B5
DK BLU/WHT
1415
Right turn signal switch output
B12
DK GRN/WHT
817
Vehicle speed signal-4000 pulses per mile
B13
WHT
121
Tachometer signal
B14
LT BLU/WHT
1414
Left turn signal switch output
B15
BLK/WHT
451
Ground
B16
TAN
31
Oil pressure indicator control
B17
LT GRN
867
ABS fail signal
A1
PNK
39
A2
DK BLU
1936
Fuel gage signal
A3
GRY
728
A4
BRN/WHT
419
A5
PNK
39
A6
YEL/BLK
68
A7
BRN
358
A8
PPL/WHT
1572
A10
TAN/WHT
33
A11
LT GRN
11
A12
PPL/WHT
237
A13
ORN
640
A14
RED
225
A15
BRN/WHT
1173
A16
DK BLU
1537
A17
DK GRN
135
B1
BRN
9
B2
GRY
8
B3
BLK
650
Ground
B4
WHT
375
B5
DK BLU/WHT
1415
B12
DK GRN/WHT
817
B13
WHT
121
Tachometer signal
B14
LT BLU/WHT
1414
B15
BLK/WHT
451
Ground
B16
TAN
31
B17
LT GRN
867
ABS fail signal
