4 inch stroker crank vs stock crank...FI application pros and cons???
Old 02-08-2009, 11:03 PM
LM7 Sportside Z71's Avatar
Default 4 inch stroker crank vs stock crank...FI application pros and cons???
Im boosting my stock aluminum 346...bare blocked it and found out i spun a rod bearing....so im wondering what i should do? I plan on 600-800rwhp with my setup. should i buy a stock crank and have it polished or just say **** it get the 4 inch and stroke it out to a 383? the engine is getting arp fasteners, forged rods, forged pistons, rings, h beam bearing etc...also wondering what a safe rwhp number is for my stock aluminum block? all input is greatly appreciated
keep in mind i want this to be very reliable and hope in only doing it one time
Old 02-08-2009, 11:28 PM
elias_799's Avatar
you will run in to head lifting issues at around 950whp, before the block goes. and if you have the money go with the stroker crank, it will help you make more power on less psi. good luck
Old 02-11-2009, 09:11 PM
barnat's Avatar
Default stock
Ive got a perfect 5.3 truck crank that was allready polished that I never used ,if needed and you go the stock route!~
Old 02-11-2009, 09:41 PM
pmbmax's Avatar
cant beat having a big ARM. spools faster has more bottom end when used with lower compresion. on a street car it is a big help. just my 2 cents
Old 02-11-2009, 10:02 PM
HUNTER02SS's Avatar
Budget motor build use a stock crank, h-beam rods and forged pistons.
That will hold you for 1000hp.
Old 02-12-2009, 10:45 PM
OUTLAWZ RACING's Avatar
I wish I knew that years ago
Old 02-13-2009, 07:20 AM
chuntington101's Avatar
what the max the stock crank has been pushed to??
Old 02-13-2009, 07:46 AM
HUNTER02SS's Avatar
I think the ohio boys have made 1450fwhp?
I have made 1089rwhp.
Old 02-13-2009, 08:23 AM
Restricted User
98Z28CobraKiller's Avatar
Is that when it let go or did they run at that power level for a while?
Old 02-13-2009, 09:04 AM
HUNTER02SS's Avatar
I think they ran it for awhile. I don't believe they ever broke the crank either?
Old 02-14-2009, 07:47 AM
382ssz28's Avatar
382 here. Love the exta power. Pin the mains and there will be no problems. Altho, stock cranks will go over 1000HP.
Quick Reply: 4 inch stroker crank vs stock crank...FI application pros and cons???
