Conversions & Hybrids - Swapping a 5.3 into a 2000 z28 ?
bret97gsx
02-09-2009, 11:01 AM
Im looking into building a turbo set up for a Camaro, and Id like to drop a 5.3 into a 2000 z28. It seems pretty straight forward, just have a few questions.
Do all the accesories from the ls1 bolt up to the 5.3 motor?
Other then switching the intakes as well, is that the only things needed to complete the swap?
91ZLS6
02-09-2009, 03:34 PM
You need to drill/tap a hole for the alternator mount
bret97gsx
04-05-2009, 09:57 PM
I posted this a while back, but has anyone dropped a 5.3 into there 98-02 F body?
Pretty simple install?
the_merv
04-06-2009, 12:31 AM
Like mentioned above..the only thing that you will have to do it Drill/Tap that hole for the Alternator mount. Everything else is exactly the same.
sixpack_2_go
04-06-2009, 12:38 AM
why would you go with less cubic inches? if you want a cheap iron block get a 6.0
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
