9000th01ss
02-09-2009, 11:55 AM
I'm going to install a Circle D 3c converter and was reading up on tuning.
My question is about TCC duty cycle.
4-set the TCC duty cycle min and max at there highest setting though with our unit this would serve no purpose since we have mechanically set it to always be max. In any case this will help to prolong the life of the lockup clutch by reducing slipping.
I have the TransGo HD2-B kit, do I still need to raise all these to max?
Would it hurt if I just did it and didn't need to?
I noticed while logging with HPTuners the tune is pulsing the TCC regulator valve, but the TCC doesn't apply until it's right at the tuned in apply speed.
When you say you have it mechanically set to always be at max is this your personal set up or does the transgo kit do this?
Thanks a lot.
Thanks a lot.
