Valve guide replacement in an LS6 head
Old 02-09-2009, 12:51 PM
Ironxcross's Avatar
Default Valve guide replacement in an LS6 head
What kind of guides are they? Are they cast in the head? How would you go about replacing them?
Old 02-09-2009, 02:23 PM
Formerly darynC-10/23/10
Daryn's Avatar
they should be just pressed in there. measure the OD of the guide and length and get some new ones, bring it to a machine shop and tell them u want to replace them
Old 02-09-2009, 02:37 PM
Ironxcross's Avatar
cool, but they are just pressed in? does anyone know how much they would cost, I only need one.
Old 02-09-2009, 04:35 PM
novaflash2002's Avatar
you can also have your guides knureld (nerr-ell-d). expands them internally, and actually helps reduce friction and luricates the valvestems better.
Old 02-04-2010, 01:50 PM
jconk's Avatar
is there a stock or aftermarket replacement valve guide for stock ls6 heads?
Been to several machine shops and the dealer and they cant find me one. Where do i go?
Old 02-04-2010, 01:53 PM
jrpimp00's Avatar
I had mine done on some 5.3 heads and the machine shop looked it up in a book for head components and orderd them for me. I had 2 replaced and it cost me 30 bucks including the guides. (and to do it right they should place the head in a special oven and heat it up to get the old one out and the new one in.
Quick Reply: Valve guide replacement in an LS6 head
