Which 10 bolt does a 2001 WS6 have?
Old 02-10-2009, 08:44 AM
murzyn123's Avatar
Default Which 10 bolt does a 2001 WS6 have?
i've read in this article that there's 2 10-bolts it said there's 8.2 inch and a 8.5 inch it says the 8.5 came from 1971-1996 on gm vehicles is there a chance a 01 would have one, i know it said 71-96 but can someone confirm
thanks
here's the link: http://www.chevyhiperformance.com/te...all/index.html
Old 02-10-2009, 08:54 AM
slow's Avatar
all 1993-2002 fcars have a 7.5ish rearend. (some call it a 7 1/2 some a 7 5/8)
Old 02-10-2009, 09:09 AM
murzyn123's Avatar
nice even weaker than the 8.2
i need to fix my posi in my 10 bolt since i can't afford new rear right now i was thinking about putting some axles in it and welding the axle tubes but since its 7.5 i'll just weld the axle tubes,rebuilt the posi and drive it till it breaks while saving for a midwest 9"
thanks
Old 02-10-2009, 04:00 PM
SS1875's Avatar
thanks
You won't regret saving for the Midwest Fab 9" ....bad piece!! The 10 bolt is the weak link in the F-body's especially when you mod it and hook it....one bad thing GM did with these cars. Good luck on fix and in an upgrade.
Old 02-10-2009, 05:35 PM
tootall4ata's Avatar
"Which 10 bolt does a 2001 WS6 have?"
LOL, the bad one...
Getting mine rebuilt soon, choosing marriage over a 9" or 12-bolt...
Old 02-12-2009, 02:32 PM
murzyn123's Avatar
my mechanic i gonna put new cluthes in it for $450 parts & labour not quite $2600+ for the midwest 9"
Old 02-12-2009, 11:48 PM
goldmecham's Avatar
if you have a 01 it shouldnt have clutches in it. as its a torsen style. and the 98-99 cars they dont even make replacement clutches for that i have seen.
Old 02-13-2009, 12:49 AM
9000th01ss's Avatar
$450 for a load of bs vs $2600 for a rear that works. Often times the one you can't afford is money well spent. Meaning $0 spent vs $450 for nothing.
Even if your rear had clutches, they're typically $80 a set with springs and it's a one hour job at most.
Old 02-13-2009, 12:55 AM
9000th01ss's Avatar
Come to think of it they use the Eaton Locking Differential (AKA Gov-Loc) in all trucks that have the 7.5/7.625
Maybe someone swapped one of those time bombs into your car (or plans to)
You think F Body 7.5's are weak, put a gov loc in it.
Old 02-14-2009, 08:29 AM
murzyn123's Avatar
i live in canada so the clutches are $190 everything is more here, even if i have to buy a new posi its better than one wheel peel through the whole summer
the midwest 9" is $3500 for the options i need which equals to me
$3500 x 1.25(exchange)+ tax(13% on the border)= $4943.75 CAN + Labour
so there's a choice
- $450 patch job if its clutches
- $700 roughly to put a new posi
- $5000 for the midwest( but there's no money for that)
- $0 drive with no posi(which sucks)
and you're right spending any money on the 10 bolt is useless but its either fix the posi and take a chance or drive with no posi since there's no way i can spend 5k this year on it
thanks matt
Old 02-14-2009, 10:54 AM
9000th01ss's Avatar
Changing clutches is an easy job you may be able to do yourself if you like working on cars.
It's still kind of odd because none of these cars came with clutch type differentials from the factory.
Unless your mechanic took the cover off to check.
The factory Auburns use cone gears, and the Torsens use helical gears (which don't typically wear out)
Thats why I said the only clutch type posi they put in a 7.5 was the gov loc, and you don't want that in your car. A previous owner may have put one in, doubtful, but thats the only thing that would be rebuildable.
Old 02-14-2009, 11:17 AM
Black FormulaLs1's Avatar
i went through 3 10 bolts...they are all junk..i even went with forged, axles, arp studs, auburn posi, and motive gears 3:73's, and a girdle, welded the axle tubes..it still blew up on me...so i spent $2600 on a moser 12 bolt and dont worry about it now..
Old 02-17-2009, 08:13 PM
murzyn123's Avatar
anyway i've picked up a used T A cover and a used Torsen posi from ls1tech for $200 shipped i'm just gonna upgrade it with used stuff and save for a new rear, anyone got some used Moser axles
thanks matt
Old 01-28-2011, 08:29 PM
getcha 01's Avatar
Default 98-02 LSD's
I have done plenty of researching on the factory 98-02 F body rears being that my 01 WS6 broke 3 of the 4 bolts(1 bolt would back out and snap on the housing, 3 seperate times) that hold the worm gears (LSD unit) on my torsen T2. The GM dealer here couldnt find anything, it kept showing an auburn unit for 98-00 z28/ss,t/a like most every part I've needed they all stop at 2000. I finally started just ordering 01-02 Z06 parts since almost all the drivetrain parts were same as Z06 part#s except for transmission,rearend. Anyway I ended up at a LSx speed shop and they recognized my LSD unit and gave me a # to StreetLegalPerformance. I called and SLP told me that most 98-00 F bodys got auburns, and some also had original torsen, until 01-02 they had it as an option on WS6/SS/Fhawk to opt for torsen T2 for a better road racing unit, auburn more for drag racing and that nowhere on the part or door codes will it say SLP because it was a factory equiped part made by SLP. Thats just from my experiences, I talked to atleast 10 shops in STL area b4 that and they all were reputable shops and none said they ever seen a full mechanical locked unit like that in an F body.....
Old 01-28-2011, 08:44 PM
slowl61's Avatar
well my 10 bolt is holding up like a champ. hooks hard enough to yank my driver side wheel up a lil bit.
(1) Yukon rearend installation kit (PN YK GM7.5-B, retail $138.21)
•(2) Yukon axle bearings (PN AK1563, retail $15.20 each)
•(2) Yukon axle seals (PN 8660S, retail $2.68 each)
•(2) Yukon axles (PN YAG 26059962, retail $175)
•(1) Yukon 3.42-ratio ring and pinion set (PN GM 7.5-342, retail $196.35)
•(1) Eaton limited-slip differential (PN EAT19599, retail $541.04)
•(1) TA differential cover (PN YPT3-GM7.5, retail $148.11)
•(1) TA stud kit for differential cover (PN 1815, retail $24.99)
•(2) Qts. 80W90 gear oil (GM PN 88900329, retail $6.47 each)
•(1) Bottle GM limited-slip additive (GM PN 1052358, retail $7.65)
this is the list i did, this plus welding axle tubes and straightend the housing
and its still going strong, but i do plan on going to a 9inch eventually.
put down 465whp and 411wtq so i dont think ill be rocking it too much longer..hah
Old 01-29-2011, 07:04 AM
FirstYrLS1Z's Avatar
posi carrier part numbers from GM parts manual
93-98 Auburn
2 series-2.73-26036756
3 series-3.23 & 3.42-26036755
99-02 Torsen
2 series-2.73-12471372
3 series-3.23 & 3.42-12471371
Quick Reply: Which 10 bolt does a 2001 WS6 have?
