will nitto 305's fit in wheel well?
Old 02-10-2009, 08:47 AM
dondb's Avatar
Default will nitto 305's fit in wheel well?
I was looking on the sticky at the tires and rims that will fit are cars,
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
My question is from other threads saying the Nitto's run small? SO, would the Nitto 305x35x18's fit a 18x10 inch rim w/54 mm offset even though the sticky says no. I know the tire will fit on the rim properly, i'm more concerned with rubbing in the wheel wells?????
Old 02-11-2009, 09:17 AM
NebWS6's Avatar
REAR Only
It should fit, but may need some "massaging" in areas of the fenderwell to make sure it doesn't rub...
Old 02-11-2009, 10:30 AM
dondb's Avatar
thanks for the reply...i think i'm going to return the 305's and go to the 285's.
I know the 285's will fit...i have 295's in there now... i wish Nitto drs came in 295's.
Old 02-11-2009, 04:26 PM
NebWS6's Avatar
me too, I had to settle for 285's also
