best tip=different shop, any good shop should remove then in 10-30 min tops, if press will not remove they should apply heat or grind them off
just my .02' Johnny
just my .02' Johnny
You were right. I went to another shop and they got them off pronto. Pretty much had to cut them off because of the backing plates getting in the way.
I don't think you wanna heat them up as it may mess with the hardened axle.
