Walbro fuel pump and trap door....
Old 02-10-2009, 02:16 PM
Restricted User
1BAD_LS1's Avatar
Default Walbro fuel pump and trap door....
well yesterday i installed my walbro fuel pump.... but found out that 98's used a different pump buz i had to modify the bracket!
The trap door saved alot of time though only took me about 1 1/2 hours from start to finish!
You can see how i modified the pump bracket in this picture.... Its bent way outta shap but works perfect! LMAO!
If it ever goes out again im buying the correct pump and it should only take about 30 minutes....
Old 02-10-2009, 05:01 PM
z28boy's Avatar
Same way I did mine only mine has 2 walbro.
Old 02-10-2009, 05:22 PM
Restricted User
1BAD_LS1's Avatar
how do you fit 2 pumps in the tank??????
Old 02-10-2009, 05:43 PM
z28boy's Avatar
You pretty much clamp them together it is a little tight but it works there is a thread in the stickeys that MIGHTYMOUSE did a write up on with pics. The pics say it all. It is a good cheap way to get a little more out of the system. PROPS TO MM.
Old 02-10-2009, 06:01 PM
Restricted User
1BAD_LS1's Avatar
ill have to check that out!
