cts-v t56 into rx7? Help!
Old 02-10-2009, 10:30 PM
brianpeter's Avatar
Default cts-v t56 into rx7? Help!
I've installed a ls6 from the ctsv into a 2nd gen rx-7. I'm trying to install the T56 from the ctsv. Usually people use the F-body trans because it fits but I have this one so I'm going to try to make it work. The transmission has a 3 bolt flange for the driveshaft. Usually people use the c4 vette driveshaft with a slip yoke but obviously I cant. Is there a name or part number for this flange so I can have a custom shaft made? I pulled the flange off to see if it could accept a slip yoke but it has 28 spline instead of 27. Do you guys know where I could go to have this made?
Old 02-10-2009, 11:18 PM
cdk4219's Avatar
Will it even accept a slip yoke? Is there an output shaft bearing on the tail housing that the 3 hole yoke rides on, or is the output shaft internally supported?
Quick Reply: cts-v t56 into rx7? Help!
