joshs2000ss
10-10-2003, 10:20 AM
I had an idea running through my head that may have already been visited here but thought I would throw it out there anyway.
Usually the S2000 start button mod(whether you think it's too ricey or not) still requires a turn of the key before pushing the button. Still kinda cool to me but much less affective for the overall functionality or justification of doing the mod because instead of just finishing the key turn you now have an extra step to push the button.
Here's what I'm thinking:
Wire in a switch (use an airplane style flip up and then switch on type) that makes the connection of the key being in the "on" position. This way you could just leave the key in and turned to on. So, when you get in the car, you flip the switch and hit the button.
Then, when your done, just flip the switch off. (I suggested the airplane style 2 motion switch because you don't want someone turning it off during your 75 MPH cruise down thei interstate). You'll still be able to activate the alarm and lock the doors because the car will think the key is off once the switch is deactivated.
There may be problems with this because I don't know all that much about how our cars are wired. Is there more than on wire that is activated when the key is switched to on?
Any suggestions or problems with this setup up would be appreciated. Please, if you think it's ricey, I don't want to know. I'm asking about the technical side of this, not whether you like it or not.
