4l60e Help And ???? please help
Old 02-11-2009, 07:02 PM
stock302mustang's Avatar
Default 4l60e Help And ???? please help
Im checking to make sure my pump in trans is working..I pulled the top trans cooler line off top of radiator and put it bucket,nothing pumped out but it did out of the radiator oil for cooler..Does this mean its pumping or is return backing up
Old 02-11-2009, 07:32 PM
Closed ex-Sponsor Account
tptransmission's Avatar
If you trace the line back the bottom line from the transmission is going to the cooler. As long as you had pressure coming out of the top then you pump is working.
Old 02-11-2009, 07:41 PM
LS1Tech Sponsor
performabuilt's Avatar
if it was running and the fluid spraying out agreed the pump is working .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-11-2009, 07:45 PM
ls1 tech is the best!!!!
