Msd 6a or 6al??
Old 02-11-2009, 07:10 PM
1 F8L Z's Avatar
Default Msd 6a or 6al??
My motor is pretty built with stroker h/c all motor car. I was wonder do I need a msd or what?? Im no expert but what does it help or do... I got some spending $$ so dont want it to go to waste.
Old 02-11-2009, 07:13 PM
Formula350's Avatar
Might as well go 6A since we have a computer controlled rev limiter. I don't think you have to have a AL to run a window switch, if you plan to run a huge shot of NOS later.
Don't know how well they work on computer controlled cars, but if you don't want to waste money, get a Digital 6 Plus
Old 02-11-2009, 07:14 PM
Black94Z28's Avatar
The only difference between the two is the 6al has a rev limiter where the 6a doesnt. I have a 6a laying around i need to get in at some point.
Old 02-11-2009, 07:16 PM
Formula350's Avatar
Wish I knew if this Digital 6 Plus I have works :\ I'd sell you it for the price of a 6AL. I don't feel like trying to wire it up to my 90 Corolla to check though LOL
Old 02-11-2009, 07:55 PM
1 F8L Z's Avatar
what is either one of those gonna like benifit me?? Im planing N/A for a while and then maybe a big shot later down the road..
Old 02-11-2009, 07:58 PM
Formula350's Avatar
To be honest, unless you are going to run over a 150shot, you'd be wasting your money buying a multi-spark box That's my opinion though. If it's a Drag Strip Queen of a car, then get one, it might help a slight bit.
Old 02-11-2009, 08:07 PM
LT1
LT1's Avatar
I run MSD6AL, either one is fine 6AL just has rev control you can swap different chip's for a rev limiter
MSD6AL gives you stronger spark at higher RPM range. People say they don't notice the stronger spark but its more about what it does which is giving stronger spark when the opti isnt doing it at high rpm's.
BTW, if you plan to get one, i would recommend the MSD harness for it, wont have to splice any wires.
Old 02-11-2009, 08:10 PM
Formula350's Avatar
+1 on that all the way! Makes it a breeeeze!
I think MSD's # is 8876 for it. It lists it in the manual that comes with it, or you can find the manual online too if you pick up a used box.
Old 02-11-2009, 08:58 PM
1 F8L Z's Avatar
Thanks LT1 That what I wanted to know what it does and you answer it bro.. I'll look into it.
Old 02-11-2009, 09:50 PM
Black94Z28's Avatar
Will the MSD 6a box help a bolt on LT1 with possibly a cam later on? Trying to decide whether to throw it on the GTO or the Z/28 lol
Old 02-11-2009, 10:00 PM
Ponch95's Avatar
With just a cam?..the answer is no! But like Formula and everybody else is saying if you stroke it or use NOS the answer is yes it will help.
Old 02-12-2009, 03:02 PM
1 F8L Z's Avatar
mine is stroke and built for nitrous, I just thinking about running all motor for alittle while since I sold my kit. Which should I get then msd 6a or 6AL?? Im still on the factory pcm and opti. but tuned already for N/A for now... Oh also if you guys have the part # also. I got the msd coil already just need the harness and which msd..
Old 02-12-2009, 03:07 PM
ss.slp.ls1's Avatar
Well if you are not spraying, then you should be fine without one.
Old 02-12-2009, 06:48 PM
1 F8L Z's Avatar
thanks for your help guys
Quick Reply: Msd 6a or 6al??
