What gear ratio do I have?
Old 02-11-2009, 07:34 PM
MiniTransAm's Avatar
Default What gear ratio do I have?
Hey guys.
Was taking the car up to Mikey at Rapid today with the wife following behind to bring me back home. Apparently my speedo is WAAAAAAY off. I told her the most I was going was about 75 but she said she was going almost 80 the entire trip. Oops.
Is there a way for me to pull the rear diff cover and somehow identify if I have the stock gear ratio or if the previous owner installed different gears and didn't compensate in the computer for it?
The last thing I need is a ticket because I think I'm doing 70 when I'm actually doing close to 80! Thanks!
Old 02-11-2009, 07:35 PM
Oh yea, car is a 2002 WS6 with a 6 speed.
Old 02-11-2009, 07:42 PM
nemss1's Avatar
factory 6-speed gears are 3.42's
Old 02-11-2009, 07:47 PM
Right, so how do I tell if I have something other than that?
Old 02-11-2009, 11:19 PM
Elliott's94Z's Avatar
Factory M6 came w/ 3.42's
You can always call a GM dealer and give them the "vin" number and they can tell you as well.
Old 02-12-2009, 06:48 AM
That's not going to help if the guy put 4.10's in or something like that AFTERMARKET. Get what I'm saying now?
Old 02-12-2009, 08:01 AM
RARON455's Avatar
THERE IS ANOTHER WAY TO TELL, jack the car up and put it on stands, and put it in nuetral
lay under the car and watch the driveshaft, use a ujoint as a reference, have the wife or a buddy spin the tire exactly one whole revolution. and you count how many times the drive shaft spins.
Example the tire is turned one whole turn and you see the driveshaft make three whole turns and then a half turn, your gear ratio is going to be a 3.42
if the driveshaft turns 3 full turns and then 3/4 of a turn then you would have 3.73 hope this helps.
If you are running larger diameter tires that will cause the problem you have described also.
Old 02-12-2009, 08:09 AM
Fotis's Avatar
post your vin i'll tell you unless its not stock
Old 02-12-2009, 09:50 AM
That's the answer I was looking for! Thanks very much! Is there info collected some where that tells how many rotations the driveshaft will make for each gear ratio? The tires on the vehicle are the stock height.
