how much compression?
well, i spun a bearing and have to rebuild my motor. i had a 5.3 laying around and decided to take the heads and crank. basically, i need to know what kind of compression i'm looking at. here's what i have:
stock crank
stock rods
mahle +4cc 3.908 pistons http://store.summitracing.com/partde...4&autoview=sku
stock 5.3 heads
lemme know if i need to include anything else. thanks for any help, guys.
stock crank
stock rods
stock 5.3 heads
stock crank
stock rods
stock 5.3 heads
stock crank
stock rods
stock 5.3 heads
The gaskets definatly have alot to do with it. The difference between a .030 gasket and the stock .052 (or .054 or something) will change the number by a decent amount. Im sure you already know this but i know that putting .030's on my ls1 raised compression up to right around 11:1 with just that swap, so playing with a variety of gaskets will yeild your desired compression ratio.
