Best heads for torquer v.2
Old 02-12-2009, 08:11 AM
mikemunoz's Avatar
Exclamation Best heads for torquer v.2
I have the torqur v.2 cam and all bolt ons i want the best heads to make the most hp. Please help with any info
Old 02-12-2009, 09:13 AM
devinfbody's Avatar
If money is no object, go with afr's. If you don't want to spend that much, go with prc stage 2.5 5.3's.
Old 02-12-2009, 09:20 AM
zank28's Avatar
I was told the 5.3 prc's if your on a budget. It makes sense for me because i got it on a 112 lsa so theres power-torque everywhere. Idk a whole lot but if your do a fast combo, maybe the ported ls6 heads...and then there's always afr's if u got the chedda. sorry this probably doesnt help much.
Old 02-12-2009, 09:26 AM
wht01ws6ta's Avatar
5.3 heads will work well as they bump the compression up. I went with unported 243 heads on a budget build. Unported 5.3 heads might have been better for non FI.
Old 02-12-2009, 10:06 AM
mikemunoz's Avatar
Default how much
how much hp will each head give me ported and unported
Old 02-14-2009, 02:34 PM
blubox's Avatar
I'm getting the same cam and trying to make up my mind between milled cnc ls6 heads or 5.3 heads..
Old 02-14-2009, 02:51 PM
'02 WS6's Avatar
If peak hp is your main concerd I'd say AFR's, but they're pricey, so next in line I'd say PRC 5.3 stg. 2.5s.
