Western Members CA, AZ, NV, UT, CO, NM, HI
Hard to put manual in R.
Old 02-12-2009, 10:20 AM
chevystyle's Avatar
Default Hard to put manual in R.
Any ideas? Sometimes I have to play with the clutch for it to feel like it went all the way into R. But every time, it's hard to put in R.
Old 02-12-2009, 10:31 AM
hlaalu's Avatar
i had that problem with my 96, something was loose and my mechanic was able to fix it pretty easily. ill try and remember what it was sorry that wasn't helpful at all
Old 02-12-2009, 02:35 PM
ss.slp.ls1's Avatar
I would check your clutch fluid reservoir, odds are you're low or you need to bleed the system.
Old 02-12-2009, 02:44 PM
MrElectric03's Avatar
Thats a common problem when your clutch wont disengage all the way, is it a stock clutch? Had that problem with my centerforce and it went away when I put my Tex in.
Old 02-12-2009, 08:38 PM
jims73z's Avatar
If it's really hard check the reverse lockout solenoid, My car someone had unplugged it and you had to push it hard to get in reverse
Old 02-12-2009, 10:30 PM
haighter's Avatar
It is usually a reasons listed blow why your car wont go into reverse
1. Your clutch is not disengaging
A. Bad master
B. Bad slave
C. Bad fluid
D. Bad pilot bearing
E. Input shaft is hitting the back of the crank shaft
F. Your throw out bearing is stuck on the slave cylinder
2. Your transmission wont go into reverse because
A. Bad syncro
B. Broken keys
C. Broken plastic bads on shift fork
Make sure that you have your clutch fully disengaged. If it wont let you put it into reverse, put it into first grear and move forward a little then try it again. Good luck.
P. S. We also rebuild transmissions if you would like us to fix it for you. Give us at CMS a call for more info.
Old 02-12-2009, 11:04 PM
jwindbigler's Avatar
Try putting the car into first gear, and then reverse...see if that helps.
Old 02-13-2009, 04:10 AM
camarojunky74's Avatar
A. Bad master
B. Bad slave
C. Bad fluid
A. Bad syncro
B. Broken keys
word...
im calling bad hydraulics, easiest and cheapest thing to fix.
do the drill mod, grab a mighty vac and some gm dot3 brake fluid flush the system after the drill mod and bleed with a mighty vac, if the problem still persist you will have to hit up this guy^^^
Old 02-13-2009, 08:00 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
Originally Posted by camarojunky74
word...
mighty vac'ing the reservoir isnt going to do ****, come on luke! you need to bleed the system past the point of the slave cylinder
Quick Reply: Hard to put manual in R.
