Compression Ratio (Math gurus Help)
Did I calculate my compression right? The engine is a 6.0L LQ4 stock pistons L92 heads with a 65cc-camber volume. I suck at math I should have stayed in school, I came up with 9.87:1 is this correct?
Bore 4.0
Stroke 3.62
Head Chamber volume 65cc
Pistons are dished (relief pocket) I used 8cc for this
Head gasket .040 Cometic
Deck height 9.240
My pistons do stick up .009 above the deck surface @ TDC
I used 1cc for the crevice volume
Bore 4.0
Stroke 3.62
Deck height 9.240
