12 bolt questions
12 bolt questions
just picked up a roller and to my luck it had a 12 bolt in it already. it has 430 gears in it now but im gona be th400 tc 78 turbo and i need some 300 or like some 320. not firmilure w the 12 bolt but what gears do they make and is 300 or 320 gears possible? any comment will help thanks
Is it Moser or Strange? If it is Moser, keep an eye on the torque arm bolts. Moser uses 4 small bolts that come loose. Strange has 2 bolts that go through like stock.
Also, I just searched a sponsors website (jawsgear.com), and it only listed a 3.08 for the 12 bolt. Next up was 3.42.
No. What series carrier you got? sound like a 4 series. If its a 3 then you can put in some 3:23 or lower. And as for the Moser There is a fix. Just because some of these sponser on here have negleted to do it dont meen someone else hasnt.
