TCI 6 Speed Auto
Old 02-12-2009, 09:08 PM
Suaveat69's Avatar
Default TCI 6 Speed Auto
http://www.motorator.com/blog/gm/tci...c-transmission
Found this and thought it was interesting.
http://video.aol.com/video-detail/tc...008/2675418475
Old 02-12-2009, 09:27 PM
camaroracer91's Avatar
damn thats cool i wonder how much it would be
Old 02-12-2009, 09:33 PM
DannoWS6's Avatar
I want!!!
Old 02-12-2009, 09:45 PM
99Hawk262's Avatar
Sounds really expensive....I wonder if it's a true bolt-in and go. I also would be curious to see if other converters would work with it and how it would affect an existing tune? Looks really promising though. I might have to start saving for a 6-speed!
Old 02-12-2009, 10:39 PM
Closed ex-Sponsor Account
tptransmission's Avatar
I am sure it is really expensive, and the ratio splits will make even more expensive. Converters should not be a problem that portion did not change from what I have seen. Interested in the actual ratios.
Old 02-12-2009, 11:03 PM
Suaveat69's Avatar
From what I found around $5k for the complete kit. Looks like it can use any 4L80 converter.
Gear ratios: 3.08, 2.34, 1.60, 1.30, 1.00, 0.75.
The only problem is that you cannot use a shifter, you have to use the paddle shifter. TCI said they are comming out with a trans-brake for this unit.
Old 02-13-2009, 09:51 AM
dondb's Avatar
i did a google on their part number for the shift kit....and TCI is selling the paddle kit for the 4l60 and 4l80 4,5 and 6 speeds...go to their site. $579.00 for kit with digital display less without? I'm going to wait to see if there are any bugs to work out
Old 02-13-2009, 05:06 PM
99Hawk262's Avatar
That's not really bad at all considering a built 80 can come close to that.
Old 02-13-2009, 10:13 PM
I would really question the ratio splits in this transmission. Not to be the pessimist but the 1.30 fourth does not match the reduction you get from using O.D. to split the ratios should be 1.20.
Old 02-16-2009, 04:24 PM
tko0383's Avatar
I got to see this on display at SEMA 08. The paddle shift is my favorite....
Old 03-06-2009, 12:09 PM
rsm425's Avatar
You do NOT have to use the paddle shifter to shift it unless you want to manually shift it. You can use ANY 4-speed automatic shifter with it. The finalized ratios for it are: 2.97, 2.33, 1.57, 1.18, 1.0, .75. It will be avaiable as a trans/TCU only or as a kit with the paddle shifter. You can also use any lockup style 4L80-E torque converter with it.
Old 03-06-2009, 07:28 PM
99Hawk262's Avatar
Sounds promising....but will it really hold up to the extreme horsepower levels?
Old 03-06-2009, 10:17 PM
More like a 5 speed with the ratio step. 1.18 to 1.00. For the 5000 + price tag I would hope it is durable.
Old 03-07-2009, 09:22 AM
Tainted's Avatar
man thats just not very realistic for most people at $5000
Old 03-07-2009, 01:50 PM
WKF
WKF's Avatar
I was quoted yesterday around 7500 for a full kit paddle shifter , computer & theworks that it needs . They told me it was supposed to be good for 850Hp.
Old 03-07-2009, 01:58 PM
I actually heard the same quote. I just thought I would be nice.
Old 03-07-2009, 02:11 PM
Tainted's Avatar
850hp...
is that flywheel or rear wheel?
Old 03-07-2009, 03:32 PM
99Hawk262's Avatar
Starting to not sound so good, huh? $5000 is a stretch, but might be worth it. $7500...forget that. Any more info on getting the GM A6 to work in our car?
Old 03-07-2009, 04:07 PM
Stay tuned it will come and with a much better ratio spread. Although the price may give a few heart attacks.
Old 03-07-2009, 04:10 PM
WKF
WKF's Avatar
Originally Posted by Tainted
850hp...
My bad , I never asked ......
I'm not totally against spending the $7500 on a 6 speed auto ....... but it had better be a damn sweet & durable setup. I need more info on the thing. I will probably wait till someone gives it a shot first.
Quick Reply: TCI 6 Speed Auto
