17x11 on all 4's camaro LOWERED?
hey guys, i was going to set my camaro up more for road racing and i wanted to run 17x11's all the way around and i think it looks badass lol. Also, i wanted my car real low, so im going to use G2 sprigns, and i know theres ppl that use 17x11's front and rear but i was wondering if they would be able to fit with a car being that low without serious rubbing, thanks alot - cory d i'd be using 17x11 zr1 replicas 50mm offset
The first place I think it will rub is the plastic inner fender which is easily taken care of. I think carefull offset choice is going to be key to keeping them inside the fender and not hitting on the inside while turning.
94Z28rag posted the following on another thread.
Lots of guys run that setup, its the most common autocross/road race setup.
Check out the road race forum or frrax.com for more info.
You'll need to do some modifications, and you'll still get some rubbing. The severity of the rubbing will depend on how low it is, how stiff it is, and how you drive. I've run 17x11 with 315's all the way around before, but probably not as much drop as you want. Rolled rear fender lips, pounding inner fenders, adjustable panhard bar, some front fender mods are all going to be needed.
