Disconnecting fuel line
Some times its a PITA. The aluminum permanent tools are better than the cheap plastic ones. You have to try using the tool in different positions. Like rotate it 120 degrees and try again. You also have to push the fuel line towards the rail why you are pushing the disconnect tool away from the rail. Some time you just have to pull really hard on the tool. Good luck man.
