Hy
Old 02-13-2009, 01:36 PM
doc1's Avatar
Default Hy
Hello to everone and congratulation for Your web site !!
I have a Wrangler tj and i 'd like to swap to LS engine new. I' d like max 400 HP and 400-450 lbs more or less ( better more torque than 20 HP plus !! ). So what You suggest 5.7 LS1-LS2-LQ-6.0 ? and where company to buy from to make a complete turn key engine supply ?
Old 02-13-2009, 04:58 PM
c5z28's Avatar
welcome gm would be a good place to start for looking for turnkey motors. Or you can start buying used and build your own motor
Old 02-14-2009, 03:38 AM
doc1's Avatar
I prefer buy a new engine including all the things necessary ( water pump, serpentine, PCM, harness...) to do a bolt on swap. But whitch engine do you suggest ?
Old 02-19-2009, 03:01 PM
doc1's Avatar
Default r
So guys can someone help me for chossing the right engine ? Thanks
Old 02-19-2009, 09:02 PM
Bret@EFIAlchemy's Avatar
All depends on what you want to do with the jeep, search through the sponsors list and see what they offer.
Old 02-20-2009, 07:20 AM
doc1's Avatar
Ok so the thing is this : i'd like a V8 engine 5.7-60 like LS1 350-400 hp with max 400 lbs. I prefere to buy a new engine stock without upgrading like forged pistons... because i am in Italy and if the engine runs original should be surely better for manteinance. I saw that 5.7 e 6.0 more or less are similar for performance. The engine will put on wrangler tj with 37 bogger tyres an 9" axle front and rear so no problems. Ultimate thing i want to mantein manual transmission so upgrading to NV 4550 ( heavy and big ) or you can suggest something lighter but strong ( now i have NV 3550 ). Budget around 5000 usd.Thanks
Old 02-22-2009, 09:11 PM
Don't really know how your buying is going to be in italy, but the really strong manuals we use here are made by tremic. The ever popular T56 6 speed. extremely strong and not too heavy. You should be fine with the stock bottom end that you suggested as an ls1 or ls2 block.
