GXP Brakes shot at 16,000 miles
Old 02-13-2009, 05:27 PM
texasGXP08's Avatar
Default GXP Brakes shot at 16,000 miles
So today I checked out my brakes on my GXP because I noticed the pedal felt different and had a slight vibration. I cannot believe how bad my front brake are! I never beat on my brakes. The pads are literally gone. I would need a micrometer to measure the amount of actual pad left. The rotors are chewed up bad too. No possible way those can be turned. I have had my car one year, this month and it only has 16,000 miles.
I just ordered new rotors and ceramic pads for the car. I will take pics and post them next week when the parts come in.
And now my question to you is, has anyone else had this issue?
Old 02-13-2009, 07:30 PM
DUSTYWS6's Avatar
Everybody has the same problem, the stock pads get chewed up fast. You'll enjoy the ceramics, they perform the same, last ALOT longer and you won't have hardly any brake dust.
Old 02-13-2009, 07:38 PM
La06GXP's Avatar
Yeah, get the ceramics. I switched to the ceramic brake pads at about 5000 miles. I changed my front pads about a month ago with a fresh set. I could have waited because the old pads still had about half the material left on them but I had already ordered a new set. At that time, my car had 96,000 miles on it and is 3 years old. I would estimate that the ceramic pads could last 4 or 5 years before needing to be replaced. Also, a little advice. Get your rotors turned down if you get the ceramic pads. Otherwise, they will squeal a lot and be very annoying.
Old 02-13-2009, 08:08 PM
LS4SPEED's Avatar
**** its still under warranty, swap out the pads and take it to the dealer, let them change the rotors! At least till its out of warranty.
Old 02-13-2009, 10:36 PM
fastLS4's Avatar
Also upgrade your brake lines to Stainless Steel ones. The difference is HUGE
Old 02-13-2009, 11:45 PM
texasGXP08's Avatar
Do you happen to have a link or part I can look up?
Old 02-14-2009, 02:30 AM
Spade's Avatar
I would be curious as well?
Old 02-14-2009, 08:37 AM
La06GXP's Avatar
Part numbers for the ceramics:
Front: 19108021
Rear: 19108022
As for brake lines, I am thinking of getting the ones from ZZPerformance.
Old 02-14-2009, 11:38 AM
Sittingmongoose's Avatar
I replaced my stock pads at like 8000 miles and they were completly gone at that point. I just replaced my hawk pads at 16000 miles. And also at 16000 miles my rotors were heat cracked so i replaced them with r1 rotors and ebc yellow stuff pads.
Old 02-16-2009, 05:15 PM
dj_stylzpgh/GXP05's Avatar
http://brakeperformance.com/site/bra..._83284&dv=0408
This is where I got my rotors from.
Old 02-17-2009, 11:25 AM
mp4life23's Avatar
im at 30,000 miles havent touched the brakes yet stops just fine
Old 02-17-2009, 01:02 PM
texasGXP08's Avatar
BURN THE WITCH!!! LOL
Old 02-17-2009, 02:14 PM
ChefChub's Avatar
LOL I am at 65k and haven't had to replace them yet. And no I do not weigh the same as a goose...
Old 02-17-2009, 03:30 PM
texasGXP08's Avatar
I thought about that. My issue is that the dealer will put the same P.O.S. rotors on that the car already has. I bit the bullet and just bought aftermarket ones. They should be here by Friday at the latest. The wait is killing me!
Old 02-17-2009, 06:28 PM
CenTexSS's Avatar
I have 27k on my 08 Impala SS, plenty of pads but heat spots everywhere. Horrible shimmey when braking at high speeds.
Old 05-14-2009, 06:19 PM
williamGT's Avatar
Mine are shot to I think, my rotors have spider cracks.
Old 05-14-2009, 06:39 PM
06 SS's Avatar
the Impy felt like it needed brakes at about 61K, rotors were trashed, but the pads were still decent. Replaced them all with stock. I can live with doing that every 60K miles or so. Seems like it is only the GXP's that are having brake troubles.
Old 05-14-2009, 06:51 PM
LS4_SS's Avatar
Brakes and rotors are a wear item. i doubt they will warranty them
Old 05-14-2009, 07:03 PM
Panther427's Avatar
He was refuring to replacing the rotor under warrenty Which is easyier to get a warrenty for than pads
Old 05-14-2009, 08:02 PM
TheMonteMan's Avatar
i dont think that the rotors are covered either its wear and tear.
