Cammed LT1 problems
Old 02-13-2009, 06:48 PM
1fast432's Avatar
Default Cammed LT1 problems
Ok guys. Just finished putting together my lt1. I have put headers, milled the heads, and put in a lloyd elliot cam. I started it and it ran fine the first day in the garage. then i started it again to take it in to put the exhaust on cuz its on open headers now and it started idling at almost 2000 rpm. then it bogged down and stalled and wont start again. any ideas as to what the problem is? I just put the 02 sensors on so thats fine.
Old 02-13-2009, 06:49 PM
1fast432's Avatar
O ya. another thing. The battery might not be good. Would that affect it once its already running or not?
Old 02-13-2009, 07:02 PM
ElkySS's Avatar
i had a similar problem and your not gonna wanna hear what it was.
opti.
Old 02-13-2009, 07:04 PM
camzaro28's Avatar
possibly TPS or IAC, I had similar problems and that fixed em. But like many are going to mention, could be the damn opti too.
Old 02-13-2009, 07:05 PM
Toronto_LT1's Avatar
hmmm...fuel pump...
Old 02-13-2009, 07:10 PM
nik1703's Avatar
probably has nothing to do with ur cam...
Old 02-13-2009, 07:12 PM
lifeisgood's Avatar
idled up to 2k then died?
is the car tuned for the cam
Old 02-13-2009, 07:41 PM
1fast432's Avatar
i put a new opti spark in it already. i havent gotten it tuned yet and i realize thats a problem but i thought it would run good enough to drive for a couple days before the tune.
Old 02-13-2009, 09:05 PM
TABBED 5.3's Avatar
could be a couple of things, what does the car do if you try to start it? start checking all connections/wiring before you start taking things back apart
Old 02-14-2009, 04:43 AM
robsquikz28's Avatar
is it a crank no start or does it run and idle at 2000rpm and stay there or does it idle up and down
Old 02-14-2009, 08:07 AM
joelster's Avatar
x2 on the tune.
You DID get it tuned didn't you?
Old 02-14-2009, 09:21 AM
myltwon's Avatar
vacuum leak imo
Old 02-14-2009, 02:40 PM
1fast432's Avatar
it starts, then idles fine. after a couple minutes it goes up to about 2k rpm. then idles real low then dies.
Old 02-14-2009, 06:33 PM
JB_97ws6TA's Avatar
Has it set any engine codes?? The tune shouldn't make it idle high, when I ran my cam untuned it was actually the opposite and I had a hard time keeping it running. I am thinking something vaccuum related or perhaps an o2 sensor.
Old 02-14-2009, 06:48 PM
z_speedfreak's Avatar
the WP isnt weeping at all is it?
Old 02-14-2009, 07:19 PM
ss.slp.ls1's Avatar
I have read that running open headers with no extensions after the collectors can throw off the o2 sensor readings. Just throwing it out there.
Old 02-14-2009, 08:14 PM
Kevin Blown 95 TA's Avatar
That can make it run really bad once it is in closed loop.
Old 02-14-2009, 08:56 PM
1fast432's Avatar
Replied in new thread,forgot the wires going into the voltage regulator on the alternator. Only had the hot from the battery hooked up. Car would start and run off battery till the battery got low and die. Found it after pulling alt to adjust valves.Feels like a full blown race car from inside. Thanks LLOYD!!!!!!!
Old 02-14-2009, 09:32 PM
myltwon's Avatar
hence the whole "after a couple min"
either o2 related problem or IAC
