Building a Ls2 and had some questions.
I'm looking into getting an Ls2 block soon.
I have Ls6 heads and a cam-232/234 already.
What i was wondering was, i want to make it a 402 stroker. But i want to reuse my stock Ls1 crankshaft if so would it work also would i just order the regular 402 stroker type rods and pistons?
any info would help thanks
also will ls6 heads fit on this and also will this be a direct swap into a ls1 vehicle no extra sensors or any of that. http://texas-speed.com/shop/item.asp
Heads will fit right on you will need relocate knock and cam, sensors. Your LS1 crank will not give you the needed stroke to acheive 402 cubes. You will need a 402 rotating assembly. Do not take this the wrong way but it seems you need to do some very basic reading and research on this.
Yea i do need to do some research just i dont know where to look for this iron block, it does say its a LS1 but idk if its the same type of engine.
Rotating Assembly
http://texas-speed.com/shop/item.asp...d=885&catid=88
block
http://texas-speed.com/shop/item.asp...d=136&catid=42
Rotating Assembly
block
LS2 is an aluminum block. To achieve a 402, you'll need a 4" stroke crankshaft, specific pistons for the longer stroke, and its advisable to get a decent set of forged connecting rods.
Do some more research. Read this:
http://www.gmhightechperformance.com...ild/index.html
