Stock rockers to 7500rpm?
The stock rockers held up just fine in my car right to 7200. As mentioned Harland Sharpe offers a trunion replacement for 250.00. Biggest downfall is the bearin assembly can come apart on the stock units and spread needle bearings thru out the motor. The HS mod eliminates this. I am getting this done to my rockers.
I have the stock rockers and shift at 7000-7200 rpms without a problem. Besides the rockers, you need to make sure the valvetrain is setup correctly to handle that kind of rpm.
LS1Tech Premium Sponsor
We tried several aluminum aftermarket rockers on our dyno motor with valve float. At 7500 we had no issues with the stock rockers that were moded at 7500.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Originally Posted by JFM-jr
The stock rockers held up just fine in my car right to 7200. As mentioned Harland Sharp offers a trunion replacement for 250.00. Biggest downfall is the bearing assembly can come apart on the stock units and spread needle bearings thru out the motor. The HS mod eliminates this. I am getting this done to my rockers.
Originally Posted by dubrado
I saw the harland sharp upgrade, I'm thinking of doing that.
Why are you planning to spin to 7500? Single plane?
Jon
single plane and big cam....morels are going in also. I have 243's w/the sodium filled valves in it right now.
What springs? PRC? patriot extremes? PAC?
I think PAC does a great job with springs.
Good luck.
Jon
My advice would be to work with a valvetrain guy who has sucessfully done 7500+ HR LS engines with the correct parts. It's not rocket science, but it is far from throwing together valvetrain parts and hoping it works. Think LIGHT and STIFF not heavy and oversprung.
Good luck.
Jon
Good luck.
Jon
