Chevrolet Camaro 1967-2002 - Questions about swapping a 5.3 into 95 z28
Djaustin89
02-13-2009, 10:50 PM
i have a complete 2007 5.3L LM7 with 33,000 miles. It has everything from intake to oil pan, minus the alternator. It came with the wiring harness also. I'm looking to possibly pick up a 95 z28 and swap it in. Knowing the car had an LT1, would the LT1 radiator work with this engine? What all things would i need to complete this swap and make it work? I've used the search link and didn't really find the info i was looking for. Can anybody help me out here?
thanks
BigZee71
02-19-2009, 09:31 PM
You will need an fbody style acsessory bracket, waterpump and an LSx style intake & fuel rails. LS1 fbody k-member. PCM tuning, wiring up the gauges, adapters for the fuel injectors (if you use LS1 injectors).
Try searching for "ls1 into lt1/ v6 fbody" something like that, which is purty much what you'll be doing. You will also need a compatible transmission.
