PRC vs Patriot Extremes
LS1Tech Premium Sponsor
The springs are built by the same manufacturer. The PRC components are carefully built here in the U.S.A. under careful tollerences. That's the reason you'll always see the PRC install heights be very consistant while other brands have huge variances in install height. The install height is very important especially when your looking at bigger lift applications like the Torquer 3, MS4 & Tsunami camshafts...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
