a few questions
Old 02-14-2009, 03:42 PM
93TAJ.C.'s Avatar
Default a few questions
do i need to go with the lt4 knock sensor setup with my pacesetter lt's? If so, what all do i need?
I somehow ordered a water pump for a corvette instead of a trans am, so now the line to the pass. side of the therm. is pointed out horizontally instead of straight up. Is that the return line with the bleed valev on it? I cant remember and was wondering if i can make it work or if i need to get the right pump.
Does anyone know the part number to the throttle body top plate gasket?
Lastly, if i remove the oil cooler from the block, will my filter thread on just as it should? Do i need any gaskets or adapters to remove the cooler?
Old 02-14-2009, 08:15 PM
ss.slp.ls1's Avatar
I would recommend getting the LT4 knock module, it will help avoid excessive knock retard. All you have to do is replace the knock module in the PCM, that's it.
I think the lines are in the same places on all of the different styles of water pumps, but the pipes are off different lenghts and orientations. I would just get the right pump for your car.
Throttle body gasket - GM Part number: 17113074
The oil filter adapter is bolted to the oil cooler, you have to remove it to unbolt the oil cooler from the block, once you do, just bolt the oil filter adapter to the block with a new oil filter adapter gasket and you should be good to go.
Old 02-14-2009, 08:23 PM
93TAJ.C.'s Avatar
thanks man!
Old 02-15-2009, 09:26 AM
lt1-xjs's Avatar
If you have a 1993 the lt4 knock mod won't work. It has to be done with a tune.
Old 02-15-2009, 01:28 PM
ss.slp.ls1's Avatar
Didn't know that, thanks.
Quick Reply: a few questions
