stock lq4 with procharger and epp blower cam dyno
Old 02-14-2009, 06:18 PM
transdam's Avatar
Default stock lq4 with procharger and epp blower cam dyno
it made 560hp 470tq on 8.5 pounds of boost
Old 02-14-2009, 06:34 PM
wes302's Avatar
crazy power. more info on combo.
Old 02-15-2009, 09:44 AM
Abdullah's Avatar
very good power for the mods. is that power rwhp and is it SAE dynojet?
more info on the mods and the car?
Old 02-15-2009, 11:06 AM
allngn_c5's Avatar
P1 or D1 SC ?? I was expecting a little more torque, but who cares when that 470 rwtq is available at 2500 rpms probably.
Old 02-15-2009, 11:07 AM
allngn_c5's Avatar
Graph Please !!!
Old 02-15-2009, 06:10 PM
transdam's Avatar
stock 06 lq4 with epp blower cam,patriot gold springs,long tube headers, tsp true dual exhaust,fmic,p1 blower,dynojet dyno
makes 400tq at 3250rpm and over 450tq from 4250rpm to 6600rpm the tq curve is very flat and never falls off
it ran a 7.38 at 99.6 today with a 1.75 60ft
Old 02-15-2009, 07:16 PM
odarabla's Avatar
What kind of car is this and how much does it weight? With your current power level I would have guessed you would have been faster then that.. You made 90rwhp and 68rwtrq more then me and ran a little slower. Whats your setup, elevation, etc? Really not trying to say anything bad about your car but if the car is making that much power you have a lot more potential!!
https://ls1tech.com/forums/attachmen...122mph-005.jpg
Old 02-15-2009, 07:18 PM
cws T/A's Avatar
What diameter crank & blower pulley ?
Old 02-15-2009, 07:32 PM
transdam's Avatar
the car is a 6 speed with a 4.56 gear and 26 10 et drag tires went to and old unpreped track because it is close to where i live and lets me run with no cage it does have alot more in it. lauched at 2800 to 3200 and have to pedal in 1st gear and very slightly in 2nd and i had a blast driving it
also me and the car are fat i am 250 pounds and the car weighed 3700
base 6rib crank pulley not sure on size 3.0 blower pulley
Old 02-16-2009, 08:09 AM
allngn_c5's Avatar
A little more on the launch and you might see 100 mph in the 1/8. Strong car. Like that 400 rwtq at 3250.
Old 02-16-2009, 12:39 PM
transdam's Avatar
thanks
going to try again next week
Quick Reply: stock lq4 with procharger and epp blower cam dyno
