1994 heater hoses?????
Old 02-14-2009, 08:39 PM
BobH's Avatar
Default 1994 heater hoses?????
Got a 94 z28 lt1 and need heater hoses but they have a bleeder on them and it is difficult at best to find a set. Can you make any other years fit???
Thanks
bobh
Old 02-14-2009, 08:53 PM
shbox's Avatar
95s will fit with some slight modifications. You can put on individual hoses and retain the bleeders if you want, though.
Old 02-14-2009, 10:21 PM
That's MISTER MODERATOR
Paul Bell's Avatar
I have the complete heater hose from GM, brand new. It's more like two pipes with hoses swaged on the ends. It has all the bleeders. The pipes bolt onto the right side inner fender. There's one nipple that went to the throttle body? It's sealed up. Otherwise, new and never installed. How's seventy five bucks plus UPS shipping? Where are you?
Old 02-15-2009, 01:08 PM
redhot lt-1's Avatar
do what i did pull all the heater hoses cut the bleeders and rubber hose from the hard line "just cut the factory press clamps" this will allow you to remove the old hoses and leave the rigid on the hard line the same goes for the bleeder section of the heater hoes then just put new hose on with good clamps you should be good. let me know if you need more info or pic`s i`ll take some of mine and what it looks like.
Quick Reply: 1994 heater hoses?????
