Aftermarket Fuel Rail Install C5
I'm about to install a FAST 90/90 and after market fuel system in my C5 Z06. This is how I'm thinking of plumbing the fuel system; any comments or issues? Thanks for looking.
LS1TECH Sponsor
It will work fine, but there is no need for the front crossover.
Infact, it will be a more direct path to the regulator instead of flowing all the fuel through the rails.
Why not run a hose at the rear of the intake instead of hard line? Should make the rail install easier.
Why an additional filter? You still running the rear factory one?
Thanks Lonnie!
Q: Why the additional filter?
A: I have the FFS fuel system with the 'lifetime' filter in the tank. After having some injectors cleaned and seeing first hand how much crap was in the injector filter baskets convinced me I should run an additional filter I can monitor.
Q: Why not run hose in the rear instead of hard line?
A: No particular reason really except that I it needs to be as low profile as possible on the drivers side rear due to firewall contact issues.
The regulator is in-tank, what do you mean by this? At first, I was going to run the rails in series but after talking to Aeromotive and reading Kinsler's recommendations I really want to run them in parallel.
This is how Aeromotive recommends routing the fuel system for my car:
What do you think?
What do you think?
LS1TECH Sponsor
Since there is no recircluation through the rails, you could just run the front connector & block off the rear.
No need to worry about parallel feeds as your single -6 inlet is more restrictive than the rails. It is your ultimate restriction.
As for the filter, be sure it is high capacity as any drop it creates will be directly seen at the injector.... another reason the regulator should be in front of the filter, preferrably on trhe rail.
Also with the stock lines & rear mount regulator, you will still run out of presure around 700rwhp, no matter how much pump you have, or the size of the rails. Your setup with stock lines is more cosmetic than functional.
I understand the system from the firewall back is an issue at the horsepower levels you indicate but I'm not there and don't foresee myself being there anytime in the next year. I'm currently N/A and plan on staying that way. Fixing the firewall back fuel system is an endeavor that I'll undertake later when I have to drop the rear cradle. You know what a PITA it is to remove the tanks on C5.....
Thanks for the input, greatly appreciated!
