need help lt1 boltons-cam problems!
full bolt ons, thunder racing 230/236-112lsa. the car ran like ****, i change plugs, wires, lots of sensors, radiator,t-stat, header gaskets, put stock balancer back on no more underdrive. the car ran very good after all that, it didnt break up or rpms hang up anymore. after about am hour of driving rhe problems came back but not as bad. any info? its got pcm4less tuned for the cam
sorry, i changed-both temps-tps-iac-map-iat. the car runs good untill about 3 grand. if you pull in any gear around 3 grand it breakes up-sputters, i dont know how to exsplain.
i changed the plugs, wires, header geskets, t-stat, radiator, balancer. i drove it for a while and it was fine now all problems are back, rmps hang up around 2grand when stoped, if you give it a lil gas it will come down to about 900 and jump from 500-900 and almost die. it hesitates bad when you get on it likes it missing. its hard to start after hot, cranks and you have to give it gas..
I'm going to guess that you have a 97...10474610 is the GM part number. Don't settle for anything less than the Delco. Additionally, you will want to move the ICM farther away from the cylinder head, as that is the hottest part of the engine. Do a search and you'll find some information.
IMO, stick with the OEM optispark. The opinion is split on the MSD. Some people have problems with them while others have success. I am sticking with the OEM.
