Hp numbers anyone????
Old 02-15-2009, 01:07 PM
strkedltweezy's Avatar
Default Hp numbers anyone????
Well im just about finished up with my 383 build and i was wondering what hp #s ya'll guys would be expecting for it has the following mods:
383: forged shortblock with flat top pistons
AFR 195cc new eliminator heads
Ai 228/236 cam .601 lift intake, .577 exhaust @ .050
Edelbrock rpm Intake port matched
1 3/4 hooker longtubes
comp cam pro mag 1.6 rockers
11.0 cr
aluminum flywheel
msd billet distributor
super street damper ATI
Old 02-15-2009, 01:38 PM
ss.slp.ls1's Avatar
11.0 cr
aluminum flywheel
I wish I could give you a number, but damn, that thing is going to be a monster! Please post videos and pics!
Old 02-15-2009, 01:44 PM
SoxXpupPeT's Avatar
wow that thing is going to be a beast! should clear the 400 mark no problem
Old 02-15-2009, 02:13 PM
James Montigny's Avatar
426rwhp @ 6000rpm
396rwtq @ 5000rpm
Old 02-15-2009, 02:21 PM
slomarao's Avatar
How much work done to the AFR's?
Old 02-15-2009, 02:44 PM
LS1 SPEED's Avatar
450 rwhp
when do you plan to tune the car?
Old 02-15-2009, 02:56 PM
The AFR are untouched but I sent the flow numbers to Ai To get a custom cam and that what i ended up with Im gonna be recieving my pcm probably next week from pcmsforless.com but i plan on dyno tuning some time later.... my goal is somewhere from 425 to 450 at the wheels with the six speed.
Old 02-15-2009, 03:12 PM
RamAir95TA's Avatar
IMO, if the AFRs are untouched, I'd expect around 410-420rwhp, and that cam isn't going to fair as well as a bigger cam could on a 383. 383s need lots of duration to fill the cylinders, and that cam is better suited for stock ported heads on stock shortblocks. AFRs by themselves, while flowing better than stock, provide comparable gains to mildly ported stock castings when used with the same cam. No doubt, stock for stock, they are better than stock heads, but it's the POTENTIAL for those heads that will really wake your setup up.
If you go with a bigger cam, and get the AFRs ported, I don't see 450+ being a problem in the hands of a good tuner, easily. Otherwise, 410 to 420.
Old 02-17-2009, 08:14 AM
Advanced Induction's Avatar
Smile
Better heads are always a sound investment. That cam and it's brothers we've run for years will make in excess of 425rwhp SAE on stock shortblock cars with the 200cc CNC'd stock head we offer.
Online one of the most common mistakes is to focus on one aspect of the vehicle's performance to the exclusion of everything else. Of course the car will make more power at high rpm with a large cam. Question is, will it run better?
Good luck with your project!
Quick Reply: Hp numbers anyone????
