quick compression question
LS1Tech Premium Sponsor
Assuming you were running a .051" gasket to achieve the 9.1:1....with the same .051" gasket in there and 64cc chambers you'd be at 10.0:1 now.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
thanks. i have an lq4 im about to build for boost, but ill probably run it NA for a short time while i the turbo build perfected, so i was looking for a little pep while im running it, as i have a set of ls6 heads and the big stockers on the 6 liter
