Western Members CA, AZ, NV, UT, CO, NM, HI
help
Old 02-15-2009, 03:33 PM
snugans310's Avatar
Default help
just installed long tubes pacesseters and i keep getting a code with it looks like my car is running like **** cuz when i get on it i get the check engine light to blink its a misfire the code says bank 1, sensor1, fuel trim to lean , what can be cousing this issue
Old 02-15-2009, 03:37 PM
Raptor_WS6's Avatar
make sure that the plug wires are on the plugs all the way and on the coils
Old 02-15-2009, 03:38 PM
Arc00TA's Avatar
You have the same problem nearly everyone with longtubes has, O2 sensors don't work as well because they're too far downstream. Did you remove cats to put them on? And still running rear O2s?
Old 02-15-2009, 03:43 PM
Raptor_WS6's Avatar
also did you use extensions, vette 02s(they are longer), or did you use the shitty splice*n*dice wires that usually come with PS longtubes
Old 02-15-2009, 04:01 PM
snugans310's Avatar
i sliced the wires but then i welded them together i only have the primary o2s on now
snugans310's Avatar
im scanning it with my predator
Old 02-15-2009, 04:03 PM
Raptor_WS6's Avatar
i only have the primaries also and did not have a problem, i used the extensions provided by hooker tho... are you sure u didnt cross the wires or something...
i had my codes turned off for the rear 02s, cats and air
Old 02-15-2009, 04:06 PM
94'BLKBRD's Avatar
Are you running open headers?
snugans310's Avatar
i did one wire at a time ,can you turn off the codes with the predator or you got to go to a tunner
Old 02-15-2009, 04:08 PM
Raptor_WS6's Avatar
a tunner, the predator will only delete the code but it will come back
Old 02-15-2009, 04:11 PM
snugans310's Avatar
can you use the secondaries that i still have to put *** primaries then ill get the extensions or do i have to get new o2s
Old 02-15-2009, 04:20 PM
Raptor_WS6's Avatar
yes you should be able to use the others for the front, an 02 is an 02, it just secondaries because they plug into to the secondary ports and the pcm reads them as secondary because of that
someone let me know if im wrong, but i am purty sure i am not
Old 02-15-2009, 04:22 PM
snugans310's Avatar
ok ill get the extensions and if anyone has extensions let me know dont feel like ordering some lol
Old 02-15-2009, 04:28 PM
Raptor_WS6's Avatar
look on eBay, i found some for like 50 before i knew the hooker headers came with some, i sold them long time ago tho sorry
Old 02-15-2009, 04:29 PM
Raptor_WS6's Avatar
http://cgi.ebay.com/ebaymotors/Parts...3A1|240%3A1318
you really only need the 2 12 inchers, but these are the only ones i found... try a shop like CMS in Lake Elsinore or STD (ask for Joe, tell him the guys from westbound sent you) in south gate (closer to you i would think) and ask them if they have any in stock
Old 02-15-2009, 04:31 PM
94'BLKBRD's Avatar
Here are some Bosch 13111 O2's. You don't need extensions with these.
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
Old 02-15-2009, 04:32 PM
snugans310's Avatar
do i need o2 simulators for the secondaries
Old 02-15-2009, 04:33 PM
94'BLKBRD's Avatar
Just have someone local to you tune them out.
Old 02-15-2009, 04:34 PM
Raptor_WS6's Avatar
naw, you dont, just get them tunned out at a shop like STD or CMS, for some change or they might do it for free, ask them
i edited my other post with the link, btw
Old 02-15-2009, 04:37 PM
snugans310's Avatar
bought the extensions already thanks guys for the help appreciate it raptor i think i got my stock bellow if you need it in lynwood
Quick Reply: help
