Drag Racing Tech - LS1 TH400 flexplates...
View Full Version : LS1 TH400 flexplates...
patriotformula
02-15-2009, 10:16 PM
What are you guys running, which ones are working for ya, which ones have you seen fail a bunch? A buddy of mine said that a couple brands (one atleast) was having a problem tearing the whole center when hit with the Transbrake.
Please post from experience/and or what is out there. I only know of the Hughes one, speed incs flexplate, and then TCI.
Sandmann120
02-15-2009, 11:02 PM
I've been running a stock '98 flexplate for a couple years now without any issues. Just gotta use the spacer.
gator's 99TA
02-15-2009, 11:11 PM
stock flexplate.
veee8
02-16-2009, 06:46 AM
TCI here, it is very stout. You have to run a converter with the small bolt pattern, 10.75" on the th400. It also has the 4l60E pattern.
ATVracr
02-16-2009, 07:15 AM
Ati. :)
ndfrsd6
02-16-2009, 08:16 AM
i just got mine from speed inc.
Fireball
02-16-2009, 08:27 AM
Ati. :)
x2 :angel:
DanZ28
02-16-2009, 11:18 AM
Ran a TCI no issues before, now run a Meziere one.
Dan
Camaro396
02-16-2009, 11:41 AM
TCI here.
Z28/2002
02-16-2009, 11:54 AM
Running a TH350 with the TCI flexplate here
pddye
02-16-2009, 12:53 PM
TCI sfi approved flexplate here. 1 year and so far so good.
JL ws-6
02-16-2009, 12:57 PM
I"m still trying to understand how that guy tore the center out of a hughes.
I have had a hughes on my car for 3 years now and it's been fine, leaving off the transbrake for 2 years with no problems. over 100 10 second passes and probably 70 9 second passes 1/2 of which were 9.6 to 9.5 and I haven't had any problems at all.
patriotformula
02-16-2009, 01:54 PM
JL... I haven't seen it myself or heard any real convincing evidence, just hear say. I guess I'm just doing some investigating before i make the purchase... I just like my feet is all! :D
Is the Hughes one SFI btw?
tomcowle
02-16-2009, 01:56 PM
If the run-out is excessive I can totally see the center of any flexplate getting ripped out.
NemeSS
02-16-2009, 01:58 PM
stock plate with spacer 10" tc
looking to use the new JW spacer that couples ls with a SBC flexplate
camscam02
02-16-2009, 02:02 PM
hughes on the way for me. we will see if it holds up. got a good deal on it, kinda worried now but such as life.
a98ws6
02-16-2009, 05:23 PM
Whats the spacer used for on the stock one? I bought a TH400 conversion for my car and have the stock plate but dont know of a spacer?
JL ws-6
02-16-2009, 05:25 PM
Yes the hughes is SFI approved...... so that being said I dunno how it could have gotten approved if it was such a POS
patriotformula
02-16-2009, 06:30 PM
^JL... thanks for the info... Like I said it was all hearsay as far as I know. I'm glad someone who has used it chimed in! BTW I think your sig pic proves its alright to me ;)
NemeSS
02-16-2009, 06:38 PM
spacer used on lq4 engine with 4l80e
NemeSS
02-16-2009, 06:46 PM
http://www.jegs.com/i/J+W+Performance/564/80014/10002/-1
this what im thinking of using next with a neutral/internal balanced
SBC flexplate
no weights
cbra-klla
02-16-2009, 07:28 PM
anybody used the cheap SFI plate you can get on ebay??
pddye
02-17-2009, 08:37 AM
I consider the tci a pretty good deal so I wouldn't want to risk shrapnel everywhere for anything cheaper.
Camaro396
02-17-2009, 09:41 AM
It's your car, but a flexplate isn't something I'd cut corners on.
cbra-klla
02-17-2009, 05:50 PM
i wasnt really planing on getting it, just wondered
gator's 99TA
02-17-2009, 08:42 PM
who has broken a stock flexplate?
tomcowle
02-18-2009, 08:46 AM
The only stock ones I've seen broke had too much run-out or the starter gear was damaged.
I can show you a shiney new billet wheel with the center ripped out of it.
patriotformula
02-18-2009, 07:53 PM
I saw Speed Inc has one as well... I know someone said what brand it was... BTW all of these aftermarket flexplates need to have the GM adaptor used with them to work with the th400?
Camaro396
02-18-2009, 08:50 PM
I didn't use any adapter with my TCI flexplate. I had a TH400 converter built for an LS1. If you use a standard SBC/BBC th400 converter, you need to use the TCI or Hughes spacer.
