Pulling the Crank Sprocket
Old 02-15-2009, 10:48 PM
luckyhenriksen's Avatar
Default Pulling the Crank Sprocket
How to I remove this? I tried a 3 jaw puller, but the teeth were to big to fit between the gear and the block. What do you use?
Old 02-15-2009, 11:24 PM
LSX Mechanic
Damian's Avatar
Thats the crank sprocket, and I massaged your title a little bit to be more accurate and get you more responses.
I have a GM puller I bought while working at GM I use, but I'm sure others will fill in with the pullers they have.
Old 02-15-2009, 11:45 PM
addicted2myWS6's Avatar
I just took the one that I have and ground the ends down on it a little bit so they would fit. Be carefull and dont gind to much or you will break your puller.
Old 02-16-2009, 12:23 AM
Ooops.... thanks for fixing that for me so you ground down the hooks on the puller? I will try it
Old 02-16-2009, 05:52 AM
vettenuts's Avatar
You can buy the correct tool for this off of fleabay for around $10.
Old 02-16-2009, 11:55 AM
Sweet I am searching egay right now
Old 02-16-2009, 03:43 PM
vettenuts's Avatar
Here you go. Link
Old 02-16-2009, 05:31 PM
01ssreda4's Avatar
i used about a 4 inch three jaw puller that can be converted to two jaw. i used it in the two jaw configuration with great success....
Old 02-16-2009, 08:38 PM
Thanks for the link. Any tips to reinstalling it?
Old 02-16-2009, 09:33 PM
01ssreda4's Avatar
i used the pulley install tool (from hawk on here) and put my old sprocket in between the two to make it be able to seat all the way IIRC.
Old 02-16-2009, 09:39 PM
vettenuts's Avatar
This should be the right tool, as least the part # is correct but there is no photo. Link
Old 02-16-2009, 11:06 PM
Cool thanks guys
