LT1 Motor Question
Old 02-16-2009, 08:44 AM
Next level's Avatar
Default LT1 Motor Question
I have a 94 Formula and blew my motor my buddy has a 93 Formula who got into a rearend accident. I know the 93 motor is a speed density car but is there any other difference that would stop me from putting my buddies block into my car ???
Old 02-16-2009, 09:05 AM
James Montigny's Avatar
You can swap the shortblocks, the only difference being the location of the oil pressure sensor.
On a 93, it's down by the filter. On a 94+ it's on top right behind the intake manifold.
I know .. I've done it LOL
The real differences are in the emmissions, vacuum lines and fuel system.
Those impact the intake manifold and exhaust manifolds. So you can swap those over
or find a way to adapt them. (it's easier to swap)
Keep the rest of his sensors and parts, specifically the throttle body (or at least the
lower half of it since the IAC is different)
Old 02-16-2009, 01:39 PM
96lt1m6's Avatar
go for it swap the parts as mentioned. that will get you back on the road.
Old 02-16-2009, 01:41 PM
myltwon's Avatar
not neccessarily, early 94's (like mine) have the oil pressure sensor above the oil filter
Old 02-16-2009, 03:58 PM
ss.slp.ls1's Avatar
Yes they changed the location mid '94. Either way you can relocate it to use it in either position.
To the OP, If you use your intake and wiring, it should be a direct swap, minus the oil pressure sensor deal.
Old 02-16-2009, 06:26 PM
myltwon's Avatar
93 injectors are smaller as well
22# I believe vs 24#
Old 02-16-2009, 07:08 PM
lifeisgood's Avatar
the cam wasnt diff?
Old 02-16-2009, 09:13 PM
myltwon's Avatar
93-95 had the same cam, 96-97 had a different one
1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
Old 02-16-2009, 09:45 PM
lifeisgood's Avatar
ah ok
Quick Reply: LT1 Motor Question
