What is this and where can I get one?
That is your PCV line. You can get a new valve at you local parts store. If it is the rubber line that is leaking, you can replace it with some bulk 3/8" rubber emissions/fuel line. You may need a double barbed fitting if you are just splicing a section.
i think its called your PVC vacuum hose... Just go to any chevy dealership and tell em and they should know wat it is.. my got ripped and it sounded like a vacuum sucking... You can make your own but me personally dont like rigging stuff on my car so i bought a new one.... It was about 85 dollars but u cant just buy that hose... it will be all the Vacuum hoses... Its worth it though if ur ripped cuz that means the others are really weak too
