Storing the car for a year, please help...
Formerly darynC-10/23/10
just remember to change the fuel filter hen you get ready to crank it back up after a year.
hey i live not to far away... ill take care of it if youd like!!!!!
if you have a high lift cam I would back the rockers off loosen all of them that way you won't have a spring compressed for a long period of time also recommend go ahead and change the oil. Or a better Idea just throw me those keys that way I can go start it every once in awhile and keep it clean LOL
i store my c5 every year for 4-6 months. Stabil will work fine for this time period, my biggest fear is the battery leaking and destoying the sesitive electrical components below it, i generally store my battery in a warm dry place off the ground. The aluminum block is prone to oxidation and the oil probably should be changed before you drive it again. i have never had a problem with the fuel varnishing in six months. i know that the purpose of the stabil is to prevent that and i believe it works. For the effort involved in draining the tanks i would assume to just take the risk, its almost the same amount of work draining the tanks prior to storing as it is after, and i really dont think youll have a problem
