3.73's..that is the question
i want to put gears in my car and was wondering what some people thought. i really want 4.10's but i cant afford a new rear if it blows, so i was looking at 3.73s. do you even think it is worth changing from 3.42s to 3.73s.. will i see or feel a difference or should i just keep what i got..
Re: 3.73's..that is the question
If anything i would go 4.10s but it is a little risky. You want feel much difference going from 3.42s to 3.73s. Personally if i had an m6 i would save the money for a caminstall or something. Plus with your 100 shot your 3.42s will be alot more rewarding.
4.10s are definitely the way to go... that's what I have in my stock 10 bolt (with T/A Girdle) and have no complaints yet. I do suggest, however, to switch to a thicker rear end fluid if you go with 4.10s... I went with 80w140 from Redline, and mine are as quiet as the stock 3.42s now.
"3.73's..that is the question"
no no.
4.10's is the question
YES is the answer.
come on, you have six gears!
i would get 4.55's if i had FIVE gears
pumpkin mush?
hey.. the 10 bolts are a wear and tear item.
